Group: DynoMotion Message: 6250 From: TKSOFT Date: 12/10/2012
Subject: New Software Release 4.30g
Please tryout our latest Software Release 4.30g with many fixes and enhancements
Major updates to the .NET / VB / C# interface and examples
.NET Help file updated here (note you may need to Properties-unblock to allow viewing)
http://www.dynomotion.com/KMotion_dotNet/Docs/Help/KMotion.Net.chm
New Simple C# Forms example demonstrates: Jogging, Global Status, exception Handling, connect/disconnect, Console Screen, Compile/Download/Execute C programs all with
only about 2 pages of code.
Available here
www.dynomotion.com/Software/KMotion430g.exe
Changes KFLOP and KMotion Released Versions 4.29 -> 4.30g  12/10/2012
KFLOP
- FPGA, FPGAW New Console Commands allows PC to write directly to FPGA
- Fix Backlash Compensation issue with Slaved axis
- Added Global ResolverFactor to allow other resolutions than 1000 counts/cycle
- Fix Open Collector mode on Step/Dir Generator outputs when muxed to JP4 and JP6
  (IO24 IO25 and IO34 IO35)
- Fix bug with Spline curve with non-Zero KLP coordinated motion smoothing
KMotionDLL
- Math options changed from "precise" to "strict" to allow use with Apps like
  Borland Builder that use different FPU rounding modes
- Fixed support for multiple boards
KMotionCNC/CoordMotion/GCode Interpreter
- Allow assigning GCode File to a User Button by *.ngc file extension
- Avoid USB Starvation when Continuously zooming GCode Viewer on large files
- Fix erroneous placement of Simulate Control after certain re-sizing of screen
- Execute/Halt toolbar buttons replaced with larger Cycle Start/Halt button which
  can also be triggered with F5 (or spacebar if currently selected)
- Fix Trajectory Planner Bug where break angles near limit would initally exact stop,
  not be rounded, then later not stop resulting in discontinuous velocity change
- KMotionCNC Stop Button no longer Kills Thread #1 which allows disable watchdog loop
  in Thread #1 to work properly after Stop
- Added WaitBitBuf/WaitNotBitBuf commands to allow coordinated motion to be syncronized
  with external signals or C programs
- Add GCode Block Delete
- GeoCorrection Table Fixes (non unity grid size) and now includes Table Offset for User defined origin
- Zero and Set buttons now update 5211-5216 (G92.3 now works properly)
- Fix offset shifts when swithing between units
- prev_dest variable added (Limit Switch direction now works with User Generated motion)
- Allow external GCode Restart vis KFLOPtoPC.c Commands
- Add Actual Feed rate Display near FRO
CoordMotion & Trajectory Planner
- Added 6 axes callbacks of Trajectory Planned Motion
- Fix issue with corner rounding for when A axis is involved
KMotion_dotNet_Interop
- Many Updates
KMotion_dotNet
- Many improvements and features
- Help file updated C:\KMotion430g\KMotion_dotNet\Docs\Help\KMotion.Net.chm
- Set/Get UserData Floats and doubles
- Removed all warnings
KFLOPWebNC Example
KMotion_dotNet Console Example
DynoMotion VB.net Example
- Updated with proper exception handling, status, connect, disconnect
VB6 Jogger Example
- Fixed and updated
VB VS2008 Jogger Example
- Fixed and updated
Simple C# Forms Example
- Shows with proper exception handling, status, connect, disconnect
- Console Callbacks, Script Command entry
- C Program Compile/Download/Execute
Mach3 Plugin
TCC67
User C Programs
- ModBus Master and Slave examples added
- MPGSmooth.c  - remove 2nd call to WaitNextTimeSlice()
- SpindleMach3JogGear.c added Mach3 Spindle message handler and sets virtual bit based on RPM Range
- MPGSmoothHardwareEnc.c added similar to MPGSmooth.c but uses hardware encoder input
- AutoPhaseFindFast.c works with brushless motors with narrow index pulses
- MPGSmoothHardwareEnc.c similar to MPGSmooth.c but uses hardware encoder input
- SoftLimits3AxisV2.c Soft limits trip and re-enable to allow motion away from limits
On-line Help
- Updated
Group: DynoMotion Message: 6252 From: criccraccroc80 Date: 12/10/2012
Subject: Re: New Software Release 4.30g
I just tried release 4.30g and so far it wasn't very successful. I have a 3 axis CNC with 2 slaved motors to move the gantry. Channel 0 is my X axis and channel 3 is slaved to channel 0 to move the other X axis motor.
With release 4.29 everything is working almost perfectly. But since release 4.30g contains features that I want for some times I decided to upgrade.
Here's what I did:
1) Downloaded and installed version 4.30g
2) Flashed kflop firmware
3) Copied config files
-Default.set
-PersistCNC.ini
-GCodeConfigCNC.txt
4) Reboot computer & kflop
5) Started KmotionCNC execute init routines: OK
6) Played with Y and Z axis: OK
7) Loaded sample G Code and executed in free space: NOT OK
2nd MOTOR of AXIS X isn't moving. I checked a few things and motor will isn't working no mater want I do.
I went back to 4.29 and everything is still working.
At the end, this will only cost me 4 bolts but it could have been much worse.
Is there a bug or did I miss something in the upgrade process?
> enhancements
> allow viewing)
> Available here
> KFLOP
> counts/cycle
> JP4 and JP6
> smoothing
> KMotionDLL
> like
> files
> screen
> button which
> velocity change
> watchdog loop
> be syncronized
> Generated motion)
> - Many Updates
> KMotion_dotNet
> - Help file updated
> KFLOPWebNC Example
> VB6 Jogger Example
> - Fixed and updated
> - Fixed and updated
> Mach3 Plugin
> TCC67
> User C Programs
> encoder input
> pulses
> encoder input
> away from limits
> On-line Help
> - Updated
Group: DynoMotion Message: 6253 From: criccraccroc80 Date: 12/10/2012
Oups!! I hit send too fast!
I will upload my init program (initStandard.c) in the files section.
Thanks for your help.
François Legrand
--- In DynoMotion@yahoogroups.com, "criccraccroc80" <flegrand80@...> wrote:
> Hi,
> Here's what I did:
> -Default.set
> -PersistCNC.ini
> -GCodeConfigCNC.txt
> > enhancements
> > allow viewing)
> > Available here
> > KFLOP
> > counts/cycle
> > JP4 and JP6
> > smoothing
> > KMotionDLL
> > like
> > files
> > screen
> > button which
> > velocity change
> > watchdog loop
> > be syncronized
> > Generated motion)
> > - Many Updates
> > KMotion_dotNet
> > - Help file updated
> > KFLOPWebNC Example
> > VB6 Jogger Example
> > - Fixed and updated
> > - Fixed and updated
> > Mach3 Plugin
> > TCC67
> > User C Programs
> > encoder input
> > pulses
> > encoder input
> > away from limits
> > On-line Help
> > - Updated
Group: DynoMotion Message: 6254 From: Tom Kerekes Date: 12/11/2012
Hi François,
Thanks for giving the new Version a try.  Sorry about the bug.  It is related to the Master - Slave order.
Please try this version:
http://www.dynomotion.com/Software/KMotion430h.exe
PS.  I don't see where your axes are ever enabled
Group: DynoMotion Message: 6255 From: François Legrand Date: 12/11/2012
Thanks for the patch. I will try it this evening.
The  axis enable and disable functions are in a separate c program. I choose to do it this way to be able to disable servos during bit changes.
François Legrand
Le 2012-12-11 03:13, "Tom Kerekes" <tk@...> a écrit :
> Hi François,
> From: criccraccroc80 <flegrand80@...>
> Sent: Monday, December 10, 2012 7:47 PM
> Subject: [DynoMotion] Re: New Software Release 4.30g
> Hi,
> Here's what I did:
> -Default.set
> -PersistCNC.ini
> -GCodeConfigCNC.txt
> > enhancements
> > allow viewing)
> > Available here
> > KFLOP
> > counts/cycle
> > JP4 and JP6
> > smoothing
> > KMotionDLL
> > like
> > files
> > screen
> > button which
> > velocity change
> > watchdog loop
> > be syncronized
> > Generated motion)
> > - Many Updates
> > KMotion_dotNet
> > - Help file updated
> > KFLOPWebNC Example
> > VB6 Jogger Example
> > - Fixed and updated
> > - Fixed and updated
> > Mach3 Plugin
> > TCC67
> > User C Programs
> > encoder input
> > pulses
> > encoder input
> > away from limits
> > On-line Help
> > - Updated
Group: DynoMotion Message: 6259 From: criccraccroc80 Date: 12/11/2012
I just tried release 4.30h and my slave axis problem is fixed. So far everything else is working pretty well and I appreciate the actual feed rate display in kmotioncnc.
Thanks again,
François Legrand
--- In DynoMotion@yahoogroups.com, François Legrand <flegrand80@...> wrote:
> Hi Tom,
> François Legrand
> > Hi François,
> > Hi,
> upgrade.
> > Here's what I did:
> > -Default.set
> > -PersistCNC.ini
> > -GCodeConfigCNC.txt
> worse.
> > > enhancements
> > > allow viewing)
> > > Available here
> > > KFLOP
> > > counts/cycle
> > > JP4 and JP6
> > > smoothing
> > > KMotionDLL
> > > like
> > > files
> > > screen
> > > button which
> > > velocity change
> > > watchdog loop
> > > be syncronized
> > > Generated motion)
> > > - Many Updates
> > > KMotion_dotNet
> > > - Help file updated
> > > KFLOPWebNC Example
> > > VB6 Jogger Example
> > > - Fixed and updated
> > > - Fixed and updated
> > > Mach3 Plugin
> > > TCC67
> > > User C Programs
> > > encoder input
> > > pulses
> > > encoder input
> > > away from limits
> > > On-line Help
> > > - Updated
